Good day everyone I am interested in knowing what sort of cement sealing products are available ,they could be clear or paint finishes its uncertain to me which way to go because I live in S.Ontario and the cement apparently is a high air content mix and I dont know if the cement truck brought the correct mixture or skimped on it because the top surface is begining to chip off and I avoid using any salt to deice for fear of making more damage.I have used some claer sealer about 2 years ago I would like to take further protection. Thanks Pete.
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
You may want to try posting this at the Breaktime forum as well. May get more answers there. I don't really know if a sealer will prevent what I would call "spalling" of the concrete surface. They may have answers for you at Breaktime.
Outside concrete should always have air-entrainment. Even with the air scaling may still happen. 1.Any finishing operation performed while bleed water is on the surface. If bleed water is worked back to the top 1/4" of the slab a very high water-cement ratio and , therefore, a low strength top surface layer is produced. 2. Insufficient or no curing. This omission often results in a weak surface skin which will scale if it is exposed to freezing and thawing in the presence of moisture and de-icing salts. 3. The concrete was poured with too low of a slump. 4" slump is workable.
I am unclear on the term slump,but I get the rest,the platform I will describe is about 6" thick with lots of rebar in it,below is a cold storage and there is 2" thick solid foam at the bottom it is visible in the storage room above my head everything there seems okay.The chipping is not a lot it is mostly at one corner at the front and it hasnt chipped more 3/16" deep,would an epoxy type paint work in a Canadian (toronto) climate to seal it,would that work I have also seen this other coating material that has a course texture that is trowelled on but havent checked out yet. thanks pete.
I'm sure others can explain "slump" in more exact terms, but in a nutshell they pour some of the concrete into a cylinder, then slide the cylinder off the concrete and see how much the concrete slumps--doesn't retain the cylindrical shape.
