Seeking a Back Issue w/ Specific Article
shspruill | Posted in General Discussion on July 5, 2007 09:33am
I am looking for an article in an issue of Fine Homebuilding that describes installing a shower pan that is almost as large as the bathroom itself. I am building a bathroom that will have about half of the space set aside for a wet room, with a large shower and spa tub — both inside a glass enclosure with an opening to enter, but no separate door. The bathroom floor will have a slight slope to the drain and there will be no rim to the shower floor portion of the wet room area. I sure hope that someone out there remembers this article and can either share the article with me or tell me which issue it is in. I will need to buy that issue. Thank you!
  1. shspruill | Jul 05, 2007 09:33pm | #1
    I am looking for an article in an issue of Fine Homebuilding that describes installing a shower pan that is almost as large as the bathroom itself. I am building a bathroom that will have about half of the space set aside for a wet room, with a large shower and spa tub -- both inside a glass enclosure with an opening to enter, but no separate door. The bathroom floor will have a slight slope to the drain and there will be no rim to the shower floor portion of the wet room area. I sure hope that someone out there remembers this article and can either share the article with me or tell me which issue it is in. I will need to buy that issue. Thank you!
  2. cermides | Jul 05, 2007 10:53pm | #2
    Shspruill,
    I'm not sure if either of these are what you're thinking about, but they should help.
    http://www.taunton.com/finehomebuilding/how-to/articles/installing-a-leakproof-shower-pan.aspx?nterms=62158,61950&ac=fp
    http://www.taunton.com/finehomebuilding/how-to/articles/sloping-floor-barrier-free-bath.aspx?ac=fp
    Good luck,
    Chris
    FHB editorial
    1. shspruill | Jul 06, 2007 03:27am | #3
      Thank you so much! I think the second article you listed is the one I am seeking.
