I need to level appx 1500 sq. ft. of slab floor before installing tile. The lowest spot is over an inch down. I’m concerned that trying to do this large an area myself will be impossible; I won’t be able to mix the stuff fast enough. I’m having a really difficult time trying to even find a local contractor to do it, although I’ve heard there are guys with pumping trucks that can do it in a snap– Help!!
there are guys in my area that will pump in the floor leveling concrete. (victoria bc) it is about $900 for a 20' x20' section. might be less if the low point is only an inch. i think the low point that i looked in to was 2.25"
Thanks for the reply- I think I'm gonna try radiant heat installers; they use a gypsum-based mix that's pumped in...I'll let you know the result...
yeah that is what this stuff was, it was a comercial resurfacing company that would also do small jobs. good luck
Consider mud. At $5 a bag compared to $30 a bag for SLC, the savings are fairly obvious, and it can be floated over a period of days so long as the cold joint ends at an expansion joint.
Regards,
Scooter
"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
Really? I'd be very leery of installing ceramic tile over a 2" bed of drywall compound...Bill
Ive done this quite a bit and I dont understand . If its an inch in a house where is it ? Pull up on the riens just a minute before you assume you have a big problem.
Have you shot and recorded the house with a water level?
Tim
Actually it's more like 2 inches in the lowest spot. We've used both a water level and a transit. The house was built in 1947 on the beach (sand), in an area that was unincorporated at the time, no plans or permits on file, so we're assuming no inspections. It's a slab on grade with no footings, so it has settled quite a bit. We've had helical piers installed, and are confident that the slab is now stable. After pulling up the carpet, we discovered that levelling concrete has been poured at least once before, so there's no telling how low that low corner really is!thanks
http://johnbridge.com/vbulletin/index.php
These guys do it for a living .
thanks
Sorry, mud is 5 to 6 parts sand to 1 part portland cement.Regards, Scooter"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
