Anyone out there ever install there own septic system? If so, how did it turn out? Thanks
Put my own in, including poured in place tank. No problems over 33 years. Just read your local regulations and a few phamplets for knowledge needed. Main things to remember - S888 flows downhill, use double compartment, record where everything is exactly for your own good.
Now (Seattle area), you have to pay $200 to take a test (relatively simple) for a license for designer or installer, can't do both here even on your own house unless near perfect soil.
Do a web search for "Infiltrator" I think. It's a plastic leach field system. Joe H
I did, I guess it is ok, why do you ask?
I built a split septic system for my house for about $500, materials and excavating (I did the labor). Kind of unconventional and legality is iffy--kind of a grey area. But then I'm quite rural. It's been about 4 years, no problems, and looks like I should never need to pump the "tank".
Split septics, I believe, are legal in parts of the Southwest and are commonly done with the more granola types of builders. I did it for the cost and because I thought it was a great idea. Still do.
Up where our cottage is, things used to be pretty loose when it came to enforcement. The typical septic tank for a house there was a car. Take your old clunker, cut a hole in one door for the inlet, one for the outlet. Or just roll down the window. Solves two problems at once....
wants to borrow it?.
"The first rule is to keep an untroubled spirit.
The second is to look things in the face and know them for what they are."
--Marcus Aurelius
