Series or parallel Elec HW
| Posted in Energy, Heating & Insulation on April 7, 2004 04:06am
I am finishing up my plan for renovating a 5-unit small apt building.  It is electric-only and the previous owner had one electric hot water heater in the basement.  To minimize it running cold he reduced the copper down to 3/8″ and then back out to 3/4 on the inlet side.  So my tenants will probably complain about no hot water.
So if I add another HWH, should I parallel or series plumb it with the existing one?
remodeler
  1. junkhound | Apr 07, 2004 04:25am | #1
    If you series you don't have to worry about them 'sharing', but for high demand periods, there is an extra 15 minutes when the second one is just a tank and not heating -aka putting btus into the water.
    In parallel, you get max elec input into the water right away, but if you do not balance the flow between the 2 WH, one will do most the heating. You almost need to put a flow meter on them in parallel and adjust with valves, as in zoned heating.
