sewer gas
maverick | Posted in General Discussion on November 27, 2006 03:46am
My house is on a septic system. when the temperature is right and the wind is calm my yard stinks to high heaven. its not the system itself, its coming from the vent pipe on the roof. the gas settles to the ground
I’ve thought about putting some heat tape around the upper stack to keep the draft going up.
anyone have a simple solution?
    BillHartmann | Nov 27, 2006 04:11am | #1
    Sometime back there was a link to someone that made a charcoal filter that went on vents just for that type of problem.
  2. VaTom | Nov 27, 2006 05:49am | #2
    I extended mine 5'.  Worked.
    1. maverick | Nov 28, 2006 01:01am | #6
      I had the tank pumped this summer.
      1. davidmeiland | Nov 28, 2006 01:22am | #7
        That could be the issue. With the cellulose layer removed from the top of the tank, more gas will back up the inlet pipe and exit thru your roof vents.
        1. maverick | Nov 28, 2006 01:27am | #8
          the gas was there before the tank was pumped also. I think I'll try the carbon filter
      2. VaTom | Nov 28, 2006 04:42am | #9
        That's nice, but I didn't suggest you had a tank problem.  I didn't either- mine was hardly used.  I just needed more height.  Think power plant, or any other polluting source.PAHS Designer/Builder- Bury it!
  3. davidmeiland | Nov 27, 2006 06:28am | #3
    How recently have you pumped the tank?
  4. dedubya | Nov 27, 2006 04:27pm | #4
    Have you had your tank pumped lately? That is usally
     a dead giveaway it is time to pump the ole poop tank.
    BillHartmann | Nov 27, 2006 06:49pm | #5
    Some emailed me the link to the company with the filter.
    http://www.sweetfilter.com/
    Again I don't know anything else about it.
    Philosophical question - if you don't have a sewer how can you have SEWER GAS.
Tool Test: You Need a Drywall Sander
We tried out a range of rotary and random-orbit sanders to compare their dust collection, quality of finish, and user fatigue after hours of sanding.
Start your subscription today and save up to 81%
