I’ve got a situation with two new fans going into bathrooms that are right next to each other. My question is whether the two fan ducts can “y” into each other so that there is only one hole punched through the roof, versus two.
This would be nicer aesthetically and a little less work to boot.
The fans are both oversized as far as CFM goes.
Any advice?
A quick checklist for success with exterior coatings.
Here is one company that makes a single remote location fan with multiple intakes and a single roof penetration.
http://www.fantech.net/bathroom.htm
Thanks for the link, there's some great stuff from the fantech website.
The clients already have their fans bought for this job so I don't think it'll work for this project, but I'll keep it in mind for future ones.
There wasn't really any planning involved before they called me up to do some bathroom remodeling, including putting these fans in, otherwise we may have been able to address the issue before the eleventh hour... They went shopping during a great hardware store sale and ended up getting all the stuff for a bathroom remodel, and that's when they decided to do the remodel!
Besides Fantech, another company is Aldes. Different style, so it fits in spaces that the Fantech might not. And I think the new ones have an additional damper that only opens at the bathroom that is turned on. The old ones exhausted all the spaces they were connected to, regardless of which one turned it on.Another cool thing is the delay off switch like the one from EFI. Keeps the fan going a set amount of time after the switch is turned off.
Be careful to make sure one fan doesn't just blow into the other room.
Have a good day
Chris
That's what I was worried about with the fans. Unlike range hoods, I don't think I've seen many bath exhaust fans with a damper right at the unit. If they do have one, then I at least wouldn't be blowing the moist air from one bath to the other, but I'd still have to make sure the ducts were sized correctly.
But if they do have dampers at the unit, then If one were running, pushing air one way against the damper and the other one were turned on, would it be a problem with pressures working against each other?
So many questions!
Pretty much all bath fans have a damper in the unit. And pretty much all of them don't work. I think at the least a couple of stand-alond dampers in the ducts would be needed.Of course, the other option is to go ahead and install the fans but "forget" to install the guts, then put a Fantech in the attic.
http://www.doityourself.com/invt/1151166
I would install my Y at the roof location coming down from the vent. Install two of these one for each fan on the legs of the Y to each vent.
The short answer is yes. I just installed two fans in adjacent rooms, bathroom and laundry room, with a Panasonic fan in each room. The fans have dampers right at the outlet. A short length of 4" flex leads from each fan to a 4-4-5 wye in the attic. From there a length of 5" goes to a sidewall cap on a gable end. The cap has its own damper too. You can buy inline dampers if you need them.
There is some know-how involved in sizing ductwork like this, knowing whether flex or rigid can/must be used, etc. I know what I did is within limits based on a chat with the inspector, who busted out his mechanical tables and gave me the parameters.
That's just the situation I'm looking at. They already bought two of the super quiet Panasonic fans.
I've got a great DIY HVAC store where I trust them implicity for sizing any vents or ducts I need. I just don't always trust them on the installation details for stuff like this.
I think I'll go ahead and put them in, and put in another inline damper or two to really keep the two rooms separated.
