I’m replacing the deteriorating cedar shingles on a gable end of my 100+ year old home in northeast Ohio. I thought it would be a straightforward job, but I was suprised to find the shingles were nailed to the (presumably origional) bevel siding. I further determined that this part of the house was done with single wall construction, that is, the bevel siding was nailed directly to the studs. I really don’t want to install the new shingles over the bevel siding, so I’ll have to bite the bullet and remove everything. This will give me a chance to better insulate the wall cavity. My problem is clearance to other additions to the house. The question is, what is the thinnest plywood sheathing I can use on this non-weight bearing wall to adequately secure the shingles. Shear strength is not an issue and the BI doesn’t care if I use sheathing or not, since it wasn’t there origionally and he considers this a “repair”. My goal is to keep the singles from projecting out from the studs any more than necessary. Any advice or input would be most appreciated.
Conrad
1/2" is all you need.
Half-inch plywood plus a product like Home Slicker (to provide air space behind shingles) adds up to about a 3/4-inch thickness. That's probably very close to the total thickness of the bevel siding, including overlap.
Thanks very much for your replies, gentlemen. Half inch plywood it is. I was seriously considering the Home Slicker, too. It's not easy to find it in my area, however. Most folks in the local building supply centers have never heard of it.
Conrad
