Folks, I’m faced with an unexpectedly complicated decision about my heating system. After extensive changes in the layout of my home (the living/dining/kitchen switched floors with the bedrooms to better use the view), it’s time to replace the boiler. A chat with a realtor left me drop-jawed that the place could be worth so much (the view!), and while I don’t care about central AC, I realize any home in this price range should have it. My question is based on these factors: lots of open walls, floors, etc., that would make running ducts easy at this point; some–perhaps significant–alteration needed in the existing hydronic layout due to changes in the floorplan (2 rads sit a few feet apart because a wall was removed between them, for example); my impression that boilers cost significantly more than furnaces for the same output; I like the quiet, even heat from the rads, but they are bulky intrusions I wouldn’t miss otherwise. Like I said, it’s replacement time anyway, so what would you do? Thanks. John
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
Folks, I'm faced with an unexpectedly complicated decision about my heating system. After extensive changes in the layout of my home (the living/dining/kitchen switched floors with the bedrooms to better use the view), it's time to replace the boiler. A chat with a realtor left me drop-jawed that the place could be worth so much (the view!), and while I don't care about central AC, I realize any home in this price range should have it. My question is based on these factors: lots of open walls, floors, etc., that would make running ducts easy at this point; some--perhaps significant--alteration needed in the existing hydronic layout due to changes in the floorplan (2 rads sit a few feet apart because a wall was removed between them, for example); my impression that boilers cost significantly more than furnaces for the same output; I like the quiet, even heat from the rads, but they are bulky intrusions I wouldn't miss otherwise. Like I said, it's replacement time anyway, so what would you do? Thanks. John
