I am helping a friend install a new shower system with 3 body jets, an overhead and handheld, it has a thermo control and a seperate diverter. Does anyone have a suggestion for how to best firmly attach the loop system for the jets to the framing? Would pex work for this or should we use copper? Thanks
Why wouldn't you use the standard drop ear elbow, same as used for a shower arm.
With it solidly attached you can use anything that you want to connect between it and the valves.
The drop elbow was my first thought too, just seems like a lot of extra fittings, I was hoping there was a T with the same fastening system as the drops. Maybe I am just dreaming
I wasn't thinking that way. And after you mentioned it I think that I have seen drop ear Tee's used for sprinkling and misting systems. but those where probably plastic.But I did a google and there are drop ear tee's.http://www.doityourself.com/invt/u238063http://www.idealtruevalue.com/servlet/the-11121/DetailNote the later does not have a threaded port, is is all solder.And if you want to go plex there is the brass drop ear elbow and separate t.http://plumbing.hardwarestore.com/52-335-pex-elbows-and-tees.aspx
Some of the newer Kohler systems use pex (or pex like) flexible supplies etc run off a firmly mounted manifold. All the fixtures are secured. Quickconnect fittings are used (if my memory is right). Prior to this, sweating copper was a time consuming job between the framing members.
Hi dollar system v. hi dollar plumber.
Have you taken a look at kohler? I'd assume some/many of the competitors are offering this also.........
http://www.quittintime.com/
Here's how I like to do it.
