shower on slab floor without membrane
thetigger | Posted in General Discussion on August 29, 2008 03:50am
The new house had a semi-circular shower built out from the rear wall of the bathroom. The walls are glass block. The dimension is 6′ diameter.
When the slab was poured the crew scooped out around the PVC pipe to allow water to slope toward it. (about 1/4 inch per foot)
I want to install an Oatley 131 series drain – WHICH DOESN’T REQUIRE A MEMBRANE and then tile the shower and the bathroom floor in 1″ tiles.
Now is everybody goin to jump on me for not using a membrane?
If I was to use a membrane how would it start and stop in a big area like this?
Will I end up with a hump in the floor where the membrane stops?
  1. MSA1 | Aug 29, 2008 04:18am | #1
    I think my only question would be whether or not they put plastic under the cement.
  2. davidmeiland | Aug 29, 2008 04:39am | #2
    You could use a surface applied membrane, either liquid or sheet. Without it your concrete will continue to absorb moisture from the shower and may very well smell lousy.
    1. thetigger | Aug 29, 2008 06:20am | #3
      i like that idea - can u suggest one?
      1. MikeHennessy | Aug 29, 2008 02:17pm | #4
        Kerdi. Not sure about using it with the drain you mentioned, tho'.
        Mike HennessyPittsburgh, PA
      2. FastEddie | Aug 29, 2008 02:21pm | #5
        Red Guard."Put your creed in your deed."   Emerson
        1. davidmeiland | Aug 29, 2008 04:56pm | #6
          Custom 9240
  3. jet | Aug 29, 2008 06:09pm | #7
    Second vote for Kerdi.
    Look here. http://www.schluter.com/8_1_kerdi.aspx
    Look at their related articles
  4. jet | Aug 29, 2008 06:15pm | #8
    Check this out.
    I know it's large but this is from the Kerdi web site and is an article by guess who.....Finehomebuilding.
    I knew this mag was good for something. LOL
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
