shower pan liner
freeman2 | Posted in Construction Techniques on April 7, 2005 06:53am
i am starting to build a HUGE custom river rock shower although i’m at the framing stage now i am thinking a ‘lil ahead. my question is about installing the liner and some rather “odd” corners (think of half of an octagon)with the entrance wall being straight. i know how to do a square pan with hospital corners but with this i’m kinda stumped,should i use patches at each corner and glue them with liner glue or is there some fancy folding or other trickery i should employ? each corner is approx. 30 degrees. help?!?!
FM2
“the large print givith, and the small print taketh away”          Tom Waits
“those with accurate observation are often called a cynic by those who have not got it” george bernard shaw
  1. Davo304 | Apr 07, 2005 08:36am | #1
    I've only done a few shower pans and they were either square or rectangular so I can't really help you out...but:
    Why don't you make a small mock-up of the shower stall frame and use a scrap piece of the actual shower pan material ( or use heavy mill plastic) and play around until you find what works.
     You could build  the frame mock-up say, out of 1X4 material or equivalent, and scale the half octogon to be say, a foot or perhaps 2 foot in size. Set the framework on a nearby table top, place the  membrane or plastic  sheeting down inside the center of the framework and use a staple gun to attach the folded seams into the corners.
      Experiment with a couple of different folds and figure out the technique that works and looks the best. Whatever technique works on the mock-up, will also work on the real McCoy...just make sure your mock-up angles (30 degrees you say?) are the same as the real shower you are building.
    I think you  would be much farther ahead if you can figure out a fold design that works, rather than resorting to cutting and patching corner seams.
    Mock-ups can save you time, money and a lot of unwanted anguish.
    Davo
    1. brownbagg | Apr 07, 2005 03:02pm | #2
      I saw a system that used a paint type system for a shower pan. forget the name but started with a " K ". I have nevered tried it but they was talking about it at JLC
      1. donpapenburg | Apr 07, 2005 03:10pm | #3
        Kerdy or something like that .
    2. Pd5190 | Apr 07, 2005 05:51pm | #7
      I will be getting a shower pan done here in a few weeks and everyone who has bid on it does hot mop. Is that still a common method across the country or just what I have run into in S. Calif?
      1. freeman2 | Apr 08, 2005 07:33am | #9
        thanx ya'll,
        i take a look at the new product suggestions, i forgot about hot mop...mmm, i'll make some calls. sometimes this forum lets you see what was right in front of you the whole time. thank you for the trees i can now see the forest.
        FM2"the large print givith, and the small print taketh away"          Tom Waits
        "those with accurate observation are often called a cynic by those who have not got it" george bernard shaw
    Mike8964 | Apr 07, 2005 03:14pm | #4
    freeman,
    you might want to look into what Schluter has. It's a pretty cool system. I finished my 1st shower with it a few weeks ago, and was pretty impressed. http://www.schluter.com/english/products/2002/sectionf/kerdi/801-index.html
    Mike
  3. donpapenburg | Apr 07, 2005 03:16pm | #5
    I did mine with the corners folded as you said . My shower has a curved wall meeting a straight wall meeting an angled wall meeting with another curved wall .  Folding works fine . I use CPE liner .  The PVC liner would not work very well, wouldnt stay put after bending and folding.
  4. Frankie | Apr 07, 2005 04:30pm | #6
    Go to http://www.laticrete.com They have a waterproof membrane system that is basically composed of a fabric which is embedded in a liquid. Kind of a paint sandwich - liquid, fabric liquid. It is ideal for odd sized shower pans. Very easy to install.
    F
  5. GreekRevivalGuy | Apr 08, 2005 07:28am | #8
    Freeman:
    How about tucked corners? I'm assuming you have two studs at each corner.
    Attached is a diagram from Noble Company's website http://www.noblecompany.com
    Obtuse angles require tucking less material than 90-degree corners. Should actually be easier.
    -Allen
Picture-Perfect Pergola
