I’m remodeling a master bath that consists of 2 rooms; one 5′ x 8′ with 2 sinks (on the 8′ wall) opening through a 27″ pocket door in a 5′ wall, to the 2nd room (5′ x 6.5′) with a toilet and then a 3′ x 5′ shower. In demolition mode I removed the plastic shower pan and discovered some light mold (mimicking the reinforcing pattern of the pan) on the slab on grade. I also found a 12″ x 12″ hole in the slab surrounding the ABS shower drainpipe. I’d like to tile the floor of both rooms and install a curbless shower using a CPE membrane under the entire floor and 6″ up the walls. My current questions are: 1. what is the best way to fill the hole in the floor so that I have a solid base for the membrane and tile? 2. Without cutting the pocket door I have about 3/4″ to install the membrane, morter bed and tile. Is there a membrane that will work on the surface of the morter bed for this, since I don’t have the depth for a 2 layer morter bed? 3. I’m considering a surface membrane over the cement backerboard on the walls. Is this “better” than 30# roofing felt or CPE under the backerboard? The shower I’m replacing failed after 12 years. I’d like to do better that with this shower.
-Deang
Greetings Dean,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
If not, you might find what you need at:
http://www.johnbridge.com/vbulletin/index.php
Cheers
'Nemo me impune lacesset'
