Simple1/2 in copper elbow sweat question
edwardh1 | Posted in General Discussion on July 24, 2006 10:17am
1/2 piece under my house. I need to sweat a copper elbow on.
do I sweat one side, wrap it with wet cloth to stay cool then do the other side?
or
2. heat it up and do both sides at once?
Than you.
  1. BUIC | Jul 24, 2006 10:24pm | #1
      Both at once is the usual way
  2. Danusan11 | Jul 24, 2006 10:27pm | #2
    both sides at same time, direct heat to one side sweat, direct heat to other side sweat
    1. edwardh1 | Jul 24, 2006 10:28pm | #3
      Thanks- !!!!!!!!!!
  3. PatchogPhil | Jul 24, 2006 11:23pm | #4
    Usually I direct the heat right smack in the middle.  Especially with 1/2 inch you can sweat both at the same time.
    DDay | Jul 25, 2006 03:16am | #5
    As others have said, do both sides at once.  If your under your house, bring some water with you just to make sure you can stop a fire if you catch something under there.  Its just a good practice.
    1. DanH | Jul 25, 2006 05:21am | #6
      In fact, it may pay to just wet down your hair in advance, before you crawl under there.
  5. plumbbill | Jul 25, 2006 05:32am | #7
    I'm gonna add just a small bit here.
    Let the copper melt the solder not the torch.
    Use a trailing pattern let torch lead the way of the solder.
    1. edwardh1 | Jul 25, 2006 03:16pm | #8
      thanks again to you all.
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
