Finishing a basement in a new house. All the load bearing walls are in place but I have to add room partitions and doors. One partition will have a 3’6″ door (will probably put in a 2X6 header with 1/2 spacer)the other will have a 8 or 9 foor opening. How do I size the header for the large opening?
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
There's nothing to size since there just non bearing walls. You can use anything there if it's just a trimmed opening. If you will have doors in the openings you can put a double 2x6 or 2x8 with a 2x4 on the top and bottom to stiffen it up. The other headers just use 2x4's on a flat.
