Good morning
After almost 30 years in the business , I got taken
Had 22 squares of roofing ripped off and new install
did everything right and it still came out wrong
Drew up an agreement with the roofer, went over mfg recommendations for roofing , use ice and water shield , even down to making sure the roofers did not over penetrate the shingles. use owens corning sure seal.
Problem is the small rear roof is minimal pitch 3/12 and i had installed insuladome skylight with small turned up flashing on sides .
the skylights had factory defects in all of the solder joints in the exterior corners
The flashing was not very long on the bottom so when we get a driving rain it comes under the flashing and into the back room
I will get some pictures but really need to come up with a solution or speak to someone knowledgeble
