In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Sleepers on concrete
HSHI | Posted in Construction Techniques on October 4, 2007 07:41am
I’ve got a question for the masses: My client wants a low profile deck put on top of concrete between the house and the garage. I figured I could install sleepers right onto the concrete with a 1/4″/ft slope, shim it level and add decking on top. Any advice about fastening the sleepers, or any warnings about the whole idea?
Any input would be appreciated.
  1. FHB Editor
    JFink | Oct 04, 2007 08:10pm | #1
    I'd put some kind of capillary break between the sleepers and the concrete to lengthen their lifespan (I assume you will use Pressure Treated sleepers), and probably fasten them with nice long tapcons.
    Justin Fink - FHB Editorial
    "Everybody wants to know what I’m on...
    What I'm on? I’m on my bike, busting my ### 6 hours a day…
    ...What are you on?"
    - Lance Armstrong
  2. Shep | Oct 04, 2007 09:59pm | #2
    Like Mr. Fink, I'd fasten them down with Tapcons, and run a strip of Vycor to keep the wood away from the concrete.
    But I'd rather rip the sleepers to the slope of the slab, than shim them level.
    Probably not a big deal either way.
  3. Piffin | Oct 04, 2007 11:14pm | #3
    I have used Tapcons, but that can get frustrating.
    GRK has a new conc screw called Caliburn I think that does this much better.
    You do not say what kind of edecking surface -
    Trex requires something like 12" to 18" under it for warrantee. Wood scientists recommend the same for real wood surfaces.
    There may be some composite makers out there who OK close installs like this.
    I use IPE over EPDM on sleepers OK
    What is the climate there? I would NOT do this where you get more than a couple inches of snow. Other wise, you can end up with ice damning and glacial destruction of the whole thing. Ice is a powerful force.
  4. user-121922 | Oct 04, 2007 11:23pm | #4
    Treated lumber with a moisture barrier should do you just fine. Tapcons are fantastic fastners for these applications.
    Edited 10/4/2007 4:29 pm ET by Big Lou in Chicago
  5. RedfordHenry | Oct 05, 2007 05:25am | #5
    Hilti or Ramset gun, red (#5) loads, and 2.5" nails.  If you don't own one, I think most tool rental place carry them.  One fastener about every 2 feet or so.  I have attached a lot of PT to concrete this way and never had a failure.  Tapcons are ok, but to be quite honest, they don't impress me a whole lot.  I've had a lot of them strip out.
How to Install Exterior Laminate PVC Siding
In this video, learn how hidden fasteners make for a seamless feature wall.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
