I need to locate a supplier of small solar-powered water pumps. Similar to the pumps used for water features in landscaping and ponds. Very low flow. But must be complete package with solar panel, pump and sensor so it only operates when bottom is submersed in shallow water.
The application is removing shallow (1″-2″) standing water on a flat roof surface after the rain.
Thanks for any suggestions.
DG/Builder
bump
'Nemo me impune lacesset'
sounds like you need something like the bilge pump/float switch set up used on small boats, 18-22ft.
CAN'T YOU ADD SOME GRIND SOME TIME????Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Can you say that in English?
DG/Builder
he's always bumbing and never grinding..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
You really want him to bump and grind for you?
now that you put it that way....
whewwwwww......Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
here:
http://www.siliconsolar.com/solar-fountain-pumps.php
Thanks David. I found some similar kits at http://www.solar-fountain.net/product_list.asp?cid=13 and bought a couple to experiment. They work fine except they don't come with a switch.
All the components are readily available individually from many sources, unfortunately nobody seems to make a turnkey system. The "packaging" was the part that I was hoping to avoid, i.e. making a platform/enclosure, etc.
DG/Builder
