Hi – working with a client who has access to old factory floor. It was true 2×4 floor and is glued and doweled with what looks to be 3/4″ hardwood pegs every 12″ OC. This floor was laid over 36″ OC beams. The floor was removed in 9′ x 4′ sections, every third board is solid 9′ length. They want to use this material in an entertaining space to create a mezzanine and they want to use as few beams as possible, ideally spanning 9′ and landing the end on top of a steel beam. Has anyone ever seen something like this used? Two engineers I spoke with don’t want anything to do with it because they can’t verify the glue used for construction nor the material. Where can we go from here?
Commercial or residential?
Residential
So, this flooring was originally laid over joists scheduled at 36"OC. Your Client wants it installed to span 9' - 3X it's previous span. Load rating at 36" was probably different than its current proposed use. But by how much does that translate when applied to greater spans?
Can you test 3 panels and document/ film tests? Apply a load to center of span until panel fails or reaches equal/ double the load rating of a traditionally framed floor.
Frankie
I would imagine the loads are significantly different (40psf residential vs whatever it was originally designed for) I didn’t think of doing a film with a centered load. Theoretically measuring the deflection with a known centered load should allow extrapolation of the designed load given span. Or the load test film is enough to get the inspector off our back.... or it’s a film of our spectacular failure and need to use more supports!
This can be calculated just like a beam. For true 2x4 using 60 psf load the load on the beam is 4/12 x 60 plf. The width of the beam is 4”. The depth is 2”. From this the span can be calculated. My power is off so I can’t use my computer. You’ll have to use your best judgment as to the species and grade.
