Solid Surface Countertop Install Tips
basswood | Posted in Construction Techniques on June 11, 2006 12:33pm
I’ve been asked to bid a solid surface install, but have only done a couple of these in the past few years (most vendors seem to use their own installers–so on most of our kitchens we just do cabinets).
I’ve done countless laminate tops, but could use advice on installing solid surface products and on bidding.
I charge $15.00/ l.f. for laminate installs (plus $45/miter). How do you price solid surface work?
On installing Corian, I just used a bead of silicone caulk to imbed the top in (after scribing with a belt sander/RA grinder).
  1. sledgehammer | Jun 11, 2006 05:39am | #1
    Most solid surface manufactures require certified installers to maintain their warrenty which is the reason for vendors using their own installers.
      basswood | Jun 11, 2006 05:35pm | #2
      Well that makes sense. Thanks.
