FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
sound deadening boards
woodpeckers | Posted in General Discussion on February 15, 2010 05:42am
i plan on installing 1/2″ soundboard and then 1/2″ sheetrock on my basement ceiling. how close can i be with the soundboard to my 5″ high hats?
    xxPaulCPxx | Feb 15, 2010 07:49pm | #1
    You would get better results from a 1/2" drywall, green glue, 5/8" drywall sandwich. Better fire resistance too!
    1. woodpeckers | Feb 15, 2010 09:01pm | #2
      so i understand this right instead of 1/2" sound deadening board use 1/2" regular drywall and on top of that 5/8" drywall. whats green glue?
        xxPaulCPxx | Feb 16, 2010 02:27am | #3
        http://www.soundproofingcompany.com/products/green_glue/
        And a longer discussion on soundproofing on JLC Forum:
        http://forums.jlconline.com/forums/showthread.php?t=40849
        I suggest using two different thickness boards for this reason (it's not mine, but it made sense to me): Sound is changed to pass through the medium it's currently in, it doesn't have to lose anymore energy to pass into another layer of the same thing, but it does have to change to pass through the thicker material.
  2. TedWhite | Apr 14, 2010 09:56am | #4
    If using a damping material, there is no need to have dis-similar thicknesses of drywall. Better to go for two thick layers to have the added mass. Double 5/8" drywall is preferred
Replace Rotten Boards in a Roof Overhang
Readers and an expert consider the source of the problem and how to fix it without completely reroofing.
  • Convert a Porch to a Mudroom
  • Podcast 599: Trees Moving Buildings, Epic Thermal Bypasses, and Supplemental Dehumidification
  • Podcast 599: Members-only Aftershow — Tools That Changed Residential Construction
  • Remodeling Done Right
BOOKS, DVDs, & MERCH
Shop the Store
  • Code Check Complete 3rd Edition
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
