has anybody here had to deal with sound issues, ive used sound deadening board, drywall, and insullation. are there better products or just how u use the existing to make a room sound-proof?
The best tool for straight, splinter-free cuts is made even better without a cord.
Depends on what you mean by 'soundproof'. If you really mean sound proof, the only way to accomplish that is to build a room-within-a-room and suspend the inner room on rubber anti-vibration mounts. That is the way it is done in recording and radio studios.
If you mean you just want to cut down on normal household sounds--like, say, kitchen noises disturbing the serenity of the classical music playing in the den, or squeaking bedsprings and inarticulate commentary on performance from the master bedroom being heard and giggled about in the kids' bedroom--then you should be using a product called Roxul Safe-N-Sound, which is a rock-wool batting designed for this purpose. Standard thermal insulation is not dense enough to absorb sound waves very well. Rock wool is much denser.
Dinosaur
One buddy of mine builds a double wall, insulates both and installs a sheet of 60 mil rubber roofing sandwitched between.
