Family room down (teenagers) Mst. Bdrm Suite Up, your thoughts on sound proofing please primarily the ceiling.
Structural steel and strong connections help a raised floor resist high winds and water.
Tell them to keep the noise down ?? :)
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Is the drywall up? New construction, renovation? Need a little more info.
New const., Mst. bdrm done, family room (basement) open.
Best thing to do is insulation and seperation of ceiling and floor. if not a drop ceiling then maybe straping hung just below the joists to separate the ceiling from the floor. Anything to stop the vibration from getting through.
Hell, just stomp on the floor.
http://www.quietsolution.com/html/quietrock.html
Cheap Tools at MyToolbox.net
See some of my work at AWorkOfWood.com
Thanks!!!!!!!PTE
You and the missus should go about your business quietly so you don't disturb the kids below, or do it in the bathroom with the water running.
Seriously, you could use metal resilient channel on the ceiling (screw it crossways to the joists and then screw the drywall to the channel without letting the drywall screws hit the joists), and/or use Quietrock drywall, or use two layers of drywall with Green Glue between them. Carpet on your bedroom floor would help. Maybe rockwool insulation in the ceiling. Consider using at least 5/8" Type X drywall.
Check this out
http://www.greengluecompany.com/understandingHowDecouplingWorks.php
http://www.greengluecompany.com/upgradingExistingFloors.php
and check out the threads from the guys building home theaters on http://www.avsforum.com
Billy
Edited 5/30/2008 10:34 pm ET by Billy
Edited 5/30/2008 10:36 pm ET by Billy
