Anyone have a good source for medicine cabinets online? I’m looking for a bunch of recessed cabins, all mirror outside with mirror inside and adjustable shelves. Sizes are RO 14.5×36 and RO 24×30.
I’ve looked at the Robern, but I don’t know if I can stomach the prices. Perhaps a notch down from there.
Thanks for the tips!
Seth
Just mirror fronts and thats it ? Do you have any particular style or look your after?
Yes, just mirror on the front, rectangular. Very simple.Seth
Well t sounds like something you can pick up at any home improvement store. Metal / wood box and a mirror here is one site. You might have to do some patchinghttp://www.bellacor.com/results.cfm?Cat=90&Page=1&Reset=1&Cat_Referer=1
Seth
If you like the Roberns take a look at the Kohlers at Lowes. Robern is a Kohler company and they share a lot (if not all the same) parts, but the prices are more reasonable. I put in a plain 20 x 26 box in my bath and we have been happy with it. Beveled mirror on the door front, flat mirror on the door back and a mirror in the back of the cabinet. The box is extruded aluminum with adjustable glass shelves. It even has a Robern sticker on it. I think it was more than a $100 bucks less than the Robern.
Ron
Those Robern's are Sweet!
I just had two put in our master bath. One recessed and one flush mount. Both with the high tension option. Allows the Queen to keep her hair curler plugged in and tucked away when not being used. Also has the defogging mirror heater.
Little pricey, but top notch. The flush mount has this channel on the bottom where one can screw in a hook to hang a hairdryer.
Bought a couple from Lowes a month ago to use in a condo I was upgrading.
Molded plastic cabinet, adj shelves, beveled mirror door, less than 15 bucks!
Same size as grubby looking old existing units, so remove and install took all of about three minutes.
