Customer has new vehicle, wider than previous and has already scraped side against garage door.
These are double doors that are limited in swing to just over 90*, therefore project into actual opening about 2″ each side.
Looking for a HEAVY DUTY hinge, similar to the one pictured in the link, that will handle the weight of a very heavy wooden door. Gaining the use of the full opening will earn me very many Brownie points.
Make em..good excuse to move the chicken and fire up the grill.
Money don't talk, It Curses
(the other Bob)
I checked Lee Valley's site; thought I'd seen a big-arsed strap hinge with an offset a while ago, but I came up dry.
Sphere's comments about the chicken failed to take into account the potentially corrosive effect of residual barbeque sauce on the strap stock; however, you probably could have them fabricated by your local machine shop or blacksmith. Assuming a 4½"x1½" 5-screw butt plate, how big would you want the offset to be (ie: How thick are the doors)? Do you think he'd need bearings on the pin loops? 'cause if so that would complicate matters....
Dinosaur
A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
But it is not this day.
How about "old fashioned" surface-mounted strap hinges? Just set them up with the pivot point a couple of inches away from the door edge. Place shim stock on the door if needed. Will look completely "normal" with a crossbuck door (which can be faked if necessary).
No electrons were harmed in the making of this post.
Dan, this is waaaaaaaaaay too simple.
One of thos "Why didn't I think of that?" moments.
Joe H
It's my job to have simple thoughts.--------------
Ever considered continuous hinges? A pair of these might work well.
http://www.hagerhinge.com/catalog/item.asp?c=26&p=510&cn=780-041
Swing clear hinges are available
Standard item used on most hospital doors ,around here hospital doors and nursing homes have 7"0x3'6" solid core fire rated doors don't know how much they weigh but it's alot .Honges are ball bearig too.
Ralph,
Use heavy gate hinges.
They have a bolt that goes into or through the door post. Screw type or bolt type. I would use the one that is a bolt, then use large washers, and use nylocks on the inside.
I usually turn the top one upside down, to prevent the door from being raised off the hinges. It also lessens the tendency for the door to sag. But sag can just as easily be dealt with, with a turnbuckle setup.
The hinge itself can be bolted through the door. In the good ones, the strap of the hinge itself doubles back over the first bolt hole.
http://www.door-hinges.com/door_specialty_hinges.php
