Set a door and installed the hinges. Heights of hinges were a little off and I probably forced the hinges, eh, a little too much. Now the hinges are sprung and there is a +/- 1/4″ gap on the hinge side of the door. Will replacing the hinge plates mounted to frame solve this or is there another fix?
There's a constant source of clean water for you to use, and all you have to do is collect it.
probably
Set a door and installed the hinges. Heights of hinges were a little off and I probably forced the hinges, eh, a little too much. Now the hinges are sprung and there is a +/- 1/4" gap on the hinge side of the door. Will replacing the hinge plates mounted to frame solve this or is there another fix?
