Some folks may not be aware of this ,
SqD is RECALLING all Arc Fault Circuit Breakers Manufactured between March 1, 2004 and September 23, 2004.
BOTH the QO and Homeline styles are being recalled .
the Cat #s are
QO115AFI
QOB115AFI
QO120AFI
QOB120AFI
HOM115AFI
HOM120AFI
The date code is stamped in RED above the wiring terminal
In addition to the catalog numbers , the following date codes are affected, CN, DN, EN, FN, GN, HN, JN.
Any breaker stamped AN, BN, or KN. are not affected
also any breakers with codes ending in L, or M are in compliance.
If you have any breakers that fall into that category, you must notify Sq D … their phone number is 1-877-202-9046 between 7:30AM – 5:00 PM EST M-F
More info at www.us.squared.com/recallafci
Sq D states that the breakers will still function as a circuit breaker but the “ARC DETECTION IS COMPROMISED”
You will need to remove the breaker , to see the info you are looking for SO,
Just remember to shut the power off before you inspect these things or, get a “licensed” electrician to do it for you
Tom
edit was for spelling
Edited 6/22/2005 4:39 pm ET by maddog
Edited 6/22/2005 4:40 pm ET by maddog
bump
bump? what does that mean?maddog
Often times one will type the word 'bump' into a single post in order to have that thread he/she is posting in to once again enter the 'recent discussion' list and then go back to the top of it's individual column listing.
In this sense the word 'bump' is just used as the common expression to announce what is being done as the reason for that post.
What this does is increases the opportunity that post has for being before the eyes of the possible viewers, thus extending the normal course in the life of the thread, which will eventually end up buried in the archives.
In this situation I 'bumped' the post because I felt the information you provided warranted the action to increase attention to the recall alert.
Cheers
be we're all in this together
A person with no sense of humor about themselves is fullashid
Thanks for that info,I wondered why the post vanished from the list so soon, too many posts not enough space? maddog
Regarding the 'recent discussion' list it depends on the frequency of new posts going on board. Put one up in early evening when many BTers are posting and it won't last long at all.
Do one at 4am and it'll last much longer before it goes into whatever file folder you designated, as you did with this post to the 'General Discussion' folder.
After the post is pushed off the bottom of the general discussion folder it will still be found in the general discussion folder and may be seen by clicking on the xxxxxMsgs found uner the filefolder title as shown in purple here.
This will open the file revealing the links to many general discussion posts and viewing old threads may be continued back in time by scrolling down that now extended viewing list of messages to the tab Next 50View Image and clicking on it.
General Discussion
172913 Msgs
Edited 6/28/2005 11:09 am ET by razzman
Thanks again, ignorance has sometimes hindered my education. That sort of explains the lack of response to this post!The day I can't help out a friend.....
That's the day I got something better to do
bump
That's the day I got something better to do "
bump (per razzman)"
