In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Square. . .but not plumb and level?
rickchem | Posted in Construction Techniques on November 20, 2002 01:54am
Hi all-
    Just wondering how you all deal with a problem I had.   I was installing a vinyl clad mulled double window unit the other day.  Put it in, went to square and level it, and the right side was off level in one direction (top slighty to the right) and the left side was out in the OTHER direction (top slightly to the left)!  Mind you, not a lot at all, but still a bit more than I like.  Unit was generally square – hard to rack the mulled units, at least to me, anyways, so I split the difference on the sides, made sure the bottom was good, and nailed ‘er up there. . . Any comments?
I could have taken the unit apart . . . but lets be honest here . . .
  1. Piffin | Nov 20, 2002 02:18am | #1
    First,
    Are you sure that your plumb stick is right on? At least a third of the ones I pick up in the stores are off.
    Second,
    Poor mulling is not uncommon, nor is unsquare windows. The most important is to have the sill setting level, then do the diagonals for square and plumb, splitting the difference in the direction that helps most.
    "The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
  2. bkhy | Nov 20, 2002 03:17am | #2
    that would be a trapezoid
  3. Schelling | Nov 20, 2002 07:32am | #3
    No matter what window you get, one in five will be like this. You did exactly the right thing. Check your level by turning it around and then split the difference.
    1. Ragnar17 | Nov 20, 2002 09:53am | #4
      Due to too many experiences like you've described, I don't even bother getting multi-gang windows from the factory anymore.  Now I just order them as single units and install them one at a time.  I don't need help to lift those heavy suckers, and I can always get my head casings to line up.
      Ragnar
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
  • Fastener System for Solving Deck Fascia Board Expansion
  • Improve Home Efficiency With Inflation Reduction Act Rebates
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
