Have a 75 year old house and want to replace the stair treads as they are pine worn out and splintering. There is no access from below. Any Ideas? Thanks
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
Video: Build a Fireplace, Brick by BrickRelated Stories
Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
Podcast 551: Members-only Aftershow—Badly-Built Homes
Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
Laminate them?
Are your current risers all equal or are the top and bottom different from the main run?
equal
so cut them out and put new ones in
I believe that they are set into runners along the sides. If they were just nailed on top I would cut them down the middle an pull them out, not damaging the sides.
Older stairs are often knotched into skirtboards and risers. It makes for a difficult removal if you are attempting to save the originals.
Removing the top tread exposes any fasteners through risers in lower treads. Still it is difficult to not damage or split the original risers and skirts.
Once the treads are removed, capping the original skirts and risers with 1/4" plywood is often an easier alternative to repairing the damage."Perfect is the enemy of Good." Morrison
Hopefully there will be little other fasteners than a nail into the riser. The skirts are painted so patching will not be an issue. Thanks
I've never done an entire stair case tread replacement, but I have swapped a few treads this way-
Remove the old tread(s) any way you can. Add 1x cleats under the old tread mortices. Glue and screw them on. Cut the new tread to the width between the stair strings, plus the depth of just one mortice.
Install the new tread by pushing it into a mortice on one side, then sliding it the other way until it catches 1/2 of the mortice on the other string. Nail in place.
I'd also use some PL Premium to hold the new treads in place.
If you have the entire staircase apart, you can probably replace most of the old tapered shims that held the old treads in place.
Exactly what I thought of doing but never done it before. Wonder if anyone else tried it. Thanks
Can you MAKE access from below??
"After the laws of Physics, everything else is opinion"
-Neil deGrasse Tyson
If Pasta and Antipasta meet is it the end of the Universe???
no access from below with out magor damage
Is major damage structural or just plaster?
the angled ceiling attached to the bottom of a stair run that is above a stairwell below get's the least scrutiny (unless it's in a closet which gets even less) by anyone's eye. Everyone is looking down and watching their step.
so how major would it be? What's below the stairs?
I'm thinking the same as you John7g.
Do it right tear out the ceiling..or roll the dice on the squeaky roulette table....eeeeeeeeeeeeeeeeeeeeeeeeee..............
"After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
Sqeaky stairs are good though. Burglars can't get up there at night without alerting everyone; neither can the teenage daughter coming in past curfew.
She can't sneak out either.
what!
Are the egress windows glued shut?
that's where thorny bushes and mud come into play
Or like I did - a Rapunzel type tower.
did you keep her hair cut short?
oldest will be 6yo in a month so I'm looking for all the clues I can get. :)
best advice I have is to spend a lot of time with her.
Read to her.
Watch those Disney movies with her head on your shoulder eating whatever she likes to eat.
Take her skating and cheer her on. let her laugh when you fall down.
Take her to church and let her know why.'cause once the hormones kick in and short circuit the brain, those instincts and memories will do more to guide her than all the talking and prison bars will ever do then.
Wonderful, warm, and touching advice.
punchline:squeeeeeek.... Who's that??It's the cat.....
