Posted earlier with some questions about replacing particle board stairs (carpeted) with oak. Have started to dissemble existing staircase. One side of it is open (has oak railing already installed) and the other side has the stair tread inletted (dadoed or partial thickness) into the stringer (the 2x timber with the cutouts to support the treads. My new treads are deeper (front to back) than the existing tread. 1. Do I trim the length of the tread to fit? 2. Do I insert the tread into the existing cutout or should I make a new stringer? Instead, can I add a piece of wood to fill in the dado (flush to the stringer’s surface) & then add a horizontal brace positioned to support the tread? 3. The cutout is wider (higher) closest to the riser; I assume for wedges. While I could add some on the lower stairs the last one (top of the staircase) will be impossible – no access. Any other thoughts/suggestions anxiously awaited. Thanks
First you need to be aware that by code the new tread cannot over hang the riser beneath it by more than a given amount.. 3/4" IIRC. So changing tread width without changing risers may be a problem.
Now if you can get past that hurdle why not just notch the lead edge of the wall end of tread so that it can slip past the end of the dado? That way you get the use of the old stringer without further demo and rebuildng.
Yes the dado is wider at the back to allow for a shim to be inserted and glued into place.
