FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
stairway trim
RTC | Posted in Construction Techniques on January 13, 2005 05:56am
i need some technique suggestions. i’m runnuing baseboards on a stairway.the treads are cantilevered about 3/4” over the risers. is there a cheater way to make the trim look good or do i need to actually notch around every tread and back to the risers. thanks
    JDRHI | Jan 13, 2005 06:47am | #1
    Baseboards on stairway?
    Thats a new one to me.
    Are you attempting to build out the stringers?
    If I`m picturin` this correctly, you`ll need to notch for each tread....however, a steady hand and an inline sabre saw might work in notching the nosing to allow for the thickness of your stock.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
    1. budreaux | Jan 13, 2005 04:54pm | #6
      If his stairs were built by the moron that built mine they seem to have forgotten about skirtboards.  My house has beaded wainscotting tucked behind the treads&risers.  I have tried to think of ways to go back in and add a skirt board.  It just looks cheap without it.  Is there a way to saw or rout a straight cut to get a skirtboard in?  I agree, he will be disappointed in baseboards.
  2. jrnbj | Jan 13, 2005 06:53am | #2
    That's how they did it in the old days...& it still looks good today...
  3. AlanRoberson | Jan 13, 2005 11:20am | #3
    They're called skirtboards. (Usually installed before the treads & risers are in.) I did this once by cutting the overhang(what you call the cantilever) off at the thickness of the trim you're using,ie, if your skirtboards are 3/4" thick cut the front of the tread 3/4" in from the wall/sheetrock whatever you've got. You do this to save yourself a lot of time with the jigsaw. ( Cut only the overhang,ie, flush with the riser below the tread!)
    Next take a stack of 1/2" thick by about 12" long strips and use them to make a pattern of the treads and risers - set a strip tight against the first riser, set a strip on top of the first tread, nail together, set a strip against the second riser, nail to 1st tread strip, and so on up the stairs. I used a brad nailer w 3/4" brads to nail the strips together. When you are done you will have a reverse pattern of your stairs. now set the pattern on your skirtboard materiel, trace it, and cut and install.
    I think i used a 1x4 to reinforce the pattern as I was doing it. Nail the strips to the 1x4 as well.
    one last thing - half of the strips will be 1/2" away from the skirtboard stock when you trace it. If you've been able to follow me so far you won't have any problem figuring out how to work around that. have fun.
    Sphere | Jan 13, 2005 04:34pm | #4
    Ask Workshop Jon from here..he just did a great job on his. Use a template..take your time, and be anal.
    Watch out for the edges, it's really fast out there...
  5. gdavis62 | Jan 13, 2005 04:47pm | #5
    There is a template tool available that is used to transfer the profile of risers and treads to a stair skirtboard.  It would be worth having for this job, unless you are clever enough to make your own.
    And yes, you will have to make the cuts for your stair tread nosings.  Most finish hardwood treads are 1" thick with a full radius bullnose, so the "cut" will be made by a careful drill-out with a 1" diameter forstner bit that has a center spike or auger.
    There are little drum sander bits you can get that will mount into the chuck of a drill.  Some of these in 3/4" diameter will come in handy to (carefully) enlarge any of the nosing cuts that need it.
    <below stuff added with edit after initial post . . . I went shopping>
    Here ya go.  Wheaton Tools makes it, or used to.  The Amazon site says "discontinued."  But I would try hard to find one, or bite the bullet and make my own.  The pic pretty much shows what you need to do.
    Edited 1/13/2005 9:00 am ET by Gene Davis
Exterior Materials for a Midcentury Home
Travis talks with the architect about his thought process for choosing the materials that create a functional and seamless aesthetic for this house.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
