What is the lowest pitch that standing-seam metal roofing can be installed on?
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
I believe 3:12, though I've seen it as low as 2:12, hell I think I've even seen it flat.
SeeYou would be the best person to answer this.
bump
It depends on the type. Snap lock, screw down, or hidden fastner and double crimp.
As previously asked: What kind of metal, true, standing seam or snap lock, ice country, etc?
What you asked was akin to asking "How many miles per gallon does a car get?"
http://www.quittintime.com/ View Image
In PEMB structures, you can get to 1/2:12; but 1:12 is usually the lowest you can get a purlin-supported roof panel system.
In an applied roof system, probably between 2/12 & 3/12--and, as CU points out, the method matters. Snap-lock systems are different than standing seam, and field-made standing seam can be different, too. Soldered systems have yet another set of rules, too.
