Question: Should I use 3/4″t&g 5ply as a substrate under a standing seam metal roof? I will install 30lb felt on the plywood before installing the standing seam roof. The attic space has adequate ventilation. The building is about 250’x 48′ with a 7/12 pitch. Will the plywood buckle without the standard spacing between sheets as is typical on other roofs?
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
Question: Should I use 3/4"t&g 5ply as a substrate under a standing seam metal roof? I will install 30lb felt on the plywood before installing the standing seam roof. The attic space has adequate ventilation. The building is about 250'x 48' with a 7/12 pitch. Will the plywood buckle without the standard spacing between sheets as is typical on other roofs?
