In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
stealing 110v from 220v at the OL
jollygiant | Posted in General Discussion on November 28, 2002 10:23am
  I have a shed at a rental house that has a 220v dryer hook-up. I want to take power off one of the 220v hot legs for the washer. Assuming I use the 10 ga. wire to the washer OL, is there anything wrong with doing this without using a subpanel? Somebody said I would mess up the “balance” of the power supply to the dryer.
  1. bake | Nov 28, 2002 11:06pm | #1
    Don't do it!!
    rjw | Nov 28, 2002 11:16pm | #2
    [Later]: IGNORE the following, see Bill's message!
    [Earlier] Size of the feed to the 110 outlet doesn't matter so much, the washer would be overfused.
    I don't think you have to worry about the "balance" of the neutral, dryer circuits are designed to run 110 circuits (like the timer circuit in the dryer and, I believe, the motor circuit) but the washer or whatever you plugged into that circuit would be overfused and it could start a fire.
    Also, any major appliance circuit should only have one device on it, per building codes.
    You would screw up thre balance of a 220 circuit that doesn't use a neutral, like many central A/C circuits.
    And, of course, you should never do any wiring if you don't follow applicable building codes!
    ________________________________________________
    "I may have said the same thing before... But my explanation, I am sure, will always be different."  Oscar Wilde
    Edited 11/28/2002 6:43:49 PM ET by Bob Walker
    Edited 11/28/2002 6:46:20 PM ET by Bob Walker
    BillHartmann | Nov 29, 2002 12:40am | #3
    My guess is that this is an older installation and it is only 3 wires. That is it does not have a separate ground.
    Also if this is a separate building I think that it is illegal without a sub-pannel to start with, but I would need to read the code to sure.
    What about lights. Are there any lights in the building?
      rjw | Nov 29, 2002 02:45am | #4
      Bill,
      Good point: if the dryer uses a three prong plug, the ground and neutral are combined so tour "extended" 110 outlet wouldn't be grounded.________________________________________________
  4. BarryO | Nov 29, 2002 03:56am | #5
    Yup, there is something wrong with it.
    I assume this is a 30A branch?  Well, you can only install 20A receptacles on 20A circuits, and 15A receptacles on 15A or 20A circuits.  Even if the wiring to them is 10 AWG.
    There's an exception for short taps (18 inches or less) to fixtures and other non-receptacles outlets, but that doesn't apply here.
    If this is a 10-3 with ground circuit, you can put in a small subpanel with a 15A or 20A breaker for the 110V washer circuit.  If this is an older style 10-2 with ground, where the neutral is connected to the appliance frame ( not sure if they ever did this for dryers, now against code, and not very safe), then you're SOL.
A Better Way to Budget in Residential Construction
Using transparent budget reports throughout the building process can help keep everyone's expectations on track.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
