FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
steel roof
jimmyk | Posted in Construction Techniques on August 11, 2004 04:23am
FIL wants to replace old roof on his horse stable with a steel roof. We’ve done many asphalt shingle roofs, but never a steel roof. Can anyone here give some insight as to what’s involved?
Thanks.
  1. brownbagg | Aug 11, 2004 04:53am | #1
    make sure it square
    coonass | Aug 11, 2004 05:52am | #2
    molten,
    Get the install details from the yard where you buy the metal. Order your sheets to length. Run a stringline representing your overhang. Use screws not nails. Use lexel not silicone. Cut with shears, nibbler or snips not abrasive blade.
    Specific questions?
    KK
      jimmyk | Aug 11, 2004 04:39pm | #4
      Thanks for the tips.
        coonass | Aug 12, 2004 01:06am | #8
        Here is a site with lots of info. Corrugated or 5-v would be tradional but I like SM (the small profile).
        http://www.mtlsales.com/
        KK
        1. brownbagg | Aug 12, 2004 01:50am | #9
          #1 tip .
          tennis shoe, chaulk line, metal roofs 5/12 pitch does not mix.
    RichColumbus | Aug 11, 2004 05:55am | #3
    Little more info, please.  Standing seam?  Panels?  Other?
    One thing that is universal... be sure to wear the mesh gloves to handle, and if you get cut... go get it professionally attended to.  Had a guy get his hand scratched by the stuff... ended up almost loosing his hand do to the infection.  Doc said that he has had many similar cases... all very serious.  Only took two days for the guy to be in BIG trouble with is hand.
      jimmyk | Aug 11, 2004 04:42pm | #5
      Not sure about the details of roof type. The structure is a horse stable, about 800 sq/ft. It's not insulated or even closed up. We aren't sure what type of steel system to use. Any suggestions? What's best value (not necessarily cheapest)?
      1. Cole | Aug 11, 2004 04:56pm | #6
        Molten,
        We build alot of barns and use steel roofing from ABC out of Omaha.  They do have a website but I can't remember it right now.  There are two different weights of steel,  26 ga. and 29 ga.  The 29 is more common, less expensive, and comes in more profiles than the 26.  We do all exposed fastener roofs and sides, standing seam is more $, and seems better suited to homes, not barns.  They carry all standard trims, channels, ridge caps and accessories for the steel to match.
        I should also mention that how your roof is framed is going to play into the equation.  rafter/purlin, rafter/sheathing, rafter only.
        Hope this helps.
        ColeCole Dean
        Dean Contracting
        RichColumbus | Aug 11, 2004 08:12pm | #7
        I can only tell you what I would use if it were mine.
        I wouldn't go for an expensive system... not on a horse barn (unless the horse barn were on my million $$ estate!)
        Vanguard type system, or maybe a rib-roof type system, would be my choices.  Be sure to follow manufacturer's specs on install... if you try to wing-it... it will probably leak.
  4. GML | Aug 12, 2004 04:32am | #10
    Drill the holes for the screws while in the pile , saves all that measuring,messing around.
Fastening Outside Corner Bead
On an outside corner formed by a double layer of drywall, the corner bead can be fastened without nails or screws.
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
  • Fine Homebuilding Issue #320 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
