I’m doing a stucco job (conventional 3 coat) and have read lots about puting two layers of tar paper or similar under the stucco. Specifically tyvek stucco wrap, 15# felt, self furring wire lath and then the 3 coats of stucco. My stucco contractor says the two layers of paper are not necessary as do most people I’ve spoken with. The literature, Journal of Light Construction, I’m referencing has some compelling articles from stucco guys who are called in to fix bad stucco jobs. They all say 2 layers is best. Questions: Does anyone have experience here? And, is there a downside to two layers?
Comments greatly appreciated.
No, I don't have any specific experience with stucco, good or bad. But let me think for a minute about your question.
Let me see......$100 for a second layer of felt, and a few hours to hang it, and for that I get to know that I did the best I could -- and I get to know it for the rest of my life.
Or, I could save the money, and worry.
Hmmmm............
I agree, the cost is minimal. I called the stucco mfg and they said don't do it!
Well, like I said, I'm no expert.
But I fail to see how it could hurt, so long as it is properly applied. Felt lays flat to the sheathing, and does not rob the stucco of any thickness.
Did the manufacturer state that it would cause a problem? Or were they simply saying that it was a waste of time/money? If the former, then I'd listen to them. If the latter, then you gotta go with your own gut feeling.
Vast projects should not be founded on half vast ideas.
There are two types of Stucco. Stucco that has cracked and Stucco that will crack."Now here at the Rock we have two rules. Memorize them until you can say them in your sleep. Rule number one: obey all rules. Rule number two: no writing on the walls." Barney Fife
Marv
Actually there is another type. Stucco that was kept moist for 28 days(!) between coats. 2 months from start to color coat. Calif. gov. spec. on CYA school building Concrete curing time to full rated strength and shrinkage determined.
Years ago, a stucco structure was the most stable during an earthquake.
SamT
HI..is there a web site to find out more info on this stucco job?? ..
That was a job I worked on
SamT
They said it would cause a problem - better listen to the experts!
Mike
