Stucco and shingles
bayouelton | Posted in General Discussion on November 16, 2006 12:40pm
Just a couple of quick questions here if anyone can help me out. I plan to replace my Katrina ex-house with an 800 sq ft cottage type / beach house with old fashioned stucco construction like that in the pic below.
1) If anyone knows anything about the materials and construction techniques required to reproduce such an exterior I would certainly appreciate your passing that info on to me. The newer stucco material popular these days that feels like Styrofoam when you touch it isn’t anything I’d be interested in. I also like the window and the chipped away plaster-on-brick look.
2) I also like the shingles on the roof but haven’t been able to find any like that, yet. I’m also thinking of a copper roof (I know it’s expensive) unless someone talks me out of it. But in any event, I definitely plan to put on a metal roof whether it ends up as copper, aluminum or steel. Thank you for your help.
Elton Hartzler
[email protected]
The Appeal of a Cottage House Design
  1. rez | Nov 19, 2006 07:21pm | #1
    Greetings b,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someone's attention that can help you with advice.
    It would help to repost your picture as an attachment and not just a copy/paste.
    Cheers
    The end move in politics is always to pick up a gun.
    R. Buckminster Fuller
      bayouelton | Nov 19, 2006 11:07pm | #4
      Thanks rez
  2. Piffin | Nov 19, 2006 07:42pm | #2
    Your embedded photo does not show up, but the one in the article linked looks like a typical Irish cottage. They are being built with twin layers of masonry block with foam between them. Another way of doing thiss DIY is to use ICF blocks which use like Legos - foam stacked forms for concrete infill and stucco over the exterior.
    You may want to shop the books tab above for books by pros for pros on masonry and concrete work, and try using the advanced search feature of this forum. There have been some excellent threads discussing all these methods
      bayouelton | Nov 19, 2006 11:07pm | #3
      Thanks for the input Piffin
      bayouelton | Dec 05, 2006 06:48am | #5
      Some!! Try a couple thousand. I don't expect anyone to cut and paste the best of those articles for me (I was too overwhelmed to read all of them but I did manage to pick up on the fact that EFIS is bad stuff) but if anyone could post a couple of good web sites that would be great. Again, I'm building a new house and want a stucco/plaster/Mediterranean architecture style exterior. Thanks.
      Elton Hartzler
      [email protected]
      1. Piffin | Dec 05, 2006 10:36pm | #6
        Actually, there is not a thing wrong with EFIS.The problems associated with it all come from poorly done Flashing sequences and design failures that do not allow for drainage planes.But for masonry construction down your way, with a stucco coat on a mediterranean style home, that being a prevalent style in the Gulf coast region, you should not have trouble finding the skilled labour to do this for you - or were you planning to do your own work? I forget.
          bayouelton | Dec 20, 2006 07:12am | #7
          Thanks again, Piffin, for another informative reply. And I do have a good contractor I trust to find the skilled labour I'll need. I would never do something like that myself without practicing on someone else's house first,  yuk, yuk.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
