Hey,
I’ve been racking my brain on this one and it dawned on me: ask the great minds on Break Time.
Was: cheapo paint grade 4′-0″ bifold doors in drywall opening
To be: 2 2′-0″ french oak doors-each weight roughly 50#
Puzzle: I want to pivot them on each side of the drywall opening.
Bifold hardware seems a bit light for this application…
I’m looking at Camtrol Double Acting Pivot Hinges which seem like overkill at $130. us per side…https://images.finehomebuilding.com/app/uploads/2019/01/26003127/234024-lg.jpg
Any one got a good solution up their sleeve? Sure would appreciate your advice.
Muchos thanks,
silver
Can you rip out the drywall, maybe rip down a cripple, so you could get in a conventional jamb with butt hinges? Or is that not the look you/they want?
I've installed closet doors with Hager pivot hinges. You might search the major hinge companies, their architectural products, to see what they have.
John
"I've installed closet doors with Hager pivot hinges." Are you talking about the hager pivot hinges like the ones in the link that are 130. or so a side?...Thanks John,silver
This is what I used: http://jhusa.net/200fd.aspx
My situation, I had 2 8' tall 1.75" solid core doors with a mirror glued to the front, they both weighed about 100lbs each, and they both had to fold open to one side as a dresser was in the way on th other.
It is a smooth as butter, and cost me about $120.
EDIT: Just the top and bottom pivots come in around $30
Tu stultus es
Also a CRX fanatic!
Look, just send me to my drawer. This whole talking-to-you thing is like double punishment.
Edited 2/21/2009 2:48 pm by xxPaulCPxx
Can't thank you enough right now XXPaulCPXXimagine that...I went to town, got organized for Monday and when I come home, the answer to my puzzle...funny thing is I've used those before...on a set of oak bifolds that was out of level...gotta say...it's a beoitch to take a door off...I mean a @##$%%$$##%y&*%^$# beitich to take a door off. I must have blocked them out of my memory...I thought about them and all I could think was PITAI'm pretty sure Windsor plywood stocks those and I even talked to Mike there, trying to pick his brain...we concured that stanley hardware was too light...but he didn't suggest these.Thanks!silver
I just wanted to say:right on!!!!!!!!!!!.The Johnson hinges were the cats ####!The drywall opening is out of plumb and I needed lots of adjustment.Which these hinges have lots of...My doors don't line up at the bottom (1 door sticks out 3/4" past the other one) I was able to tweak (skew) the hinges enough to get 1/2 of it.I thought I'd let them sit over the weekend (acclimate) and then deal with it on Monday. I had to cut 2" off the bottom so the warranty is toast.thanks again,silver
Dey Nada!
(or "It's nothing" in poorly pronunced spainish)
Tu stultus esRebuilding my home in Cypress, CAAlso a CRX fanatic!
unless those have a spring load closing action, they look like nothing worth that much mulla
Hey Mr. Piffin,Long time,no bump into...nice to see you again.Just cracked a Molson #### and I've got the blues on now-Saturday Night Blues with Holger Petersen on CBC...I don't know how to send a link but if you want smokin' blues served up world class style dial in cbc and follow the links.yeah they are spring loaded...I'm checking out plan d right now...thanks,
silver
Try Rixson pivot hinges, pricey though.
Rich
Thanks,I'll google 'em...I trust you've had good luck with them...never know when you might need to pull a horseshoe-or hinge-outta your butt.I had a funny experience with the Johnsons...right under my nose and I
ignored them.cheers, time for a gin and tonicsilver
no - it's past timeCheers!Rixson is more or less the standard
Top quality items, great if they fit the budget.
Cheers, Rich
Piffin and richThanks for the heads up on Rixsonand bottoms up-last gin and tonic of the weekend...It was great to get a 2 day weekend...not so lucky next weekend...I'll be installing base to try to keep a customer happy.cheers,silver
Make hay while the sun shines :)
