In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
subflooring
| Posted in Construction Techniques on December 8, 2002 10:28am
I have a project in Florida, a 30year old house of wood construction on a crawlspace. The sub floor is 1/2″ ply(not t&g) and some of the sheets are lain with the the joist, very spongy. Should I glue and screw 3/4″ t&g right on top of the 1/2″, rip up the 1/2″ and glue and screw the 3/4″ to the joist or lay felt on the 1/2″ and  screw the 3/4″ to the joist and 1/2 ” with no glue. The finish floor will be ceramic tike.
  1. trimmaster | Dec 08, 2002 10:57pm | #1
    From what I have experienced from remodeling is that it is easier and just as easy to rip up that 1/2" and start anew.  that way you don't have to fight all of the problems and mistakes that someone else made.
    1. steamdriven | Dec 09, 2002 07:57pm | #3
  2. Piffin | Dec 09, 2002 04:27am | #2
    For ceramic tile you need a double layer anyway but what you have to start with is worthless - worse than worthless because it is confusing you.
    A floor system is not just in the thickness of the subfloor. The connection between it and the joists needs to be good too. That is why a glued down subfloor has fewer squeeks and the total system is rated higher. I am betting that since this is in humid Florida, some of your existing sub is not only laid wrong but has begun to rot too, from the bottom up where the source of the moisture is.
    Take it all up and then you can see where the bad joists are too, and repair them, treat for termites, etc, and glue down a new 3/4" sub. Then overlay that with denshield or another 1/2" underlayment, glued and screwed @ 6-8" OC
    Now you've got ####sound solid floor system that the tiles won't bounce, crack, or lift off of.
    "The first rule is to keep an untroubled spirit.
    The second is to look things in the face and know them for what they are."
    --Marcus Aurelius
    1. steamdriven | Dec 09, 2002 07:58pm | #4
  3. andybuildz | Dec 09, 2002 11:37pm | #5
    Jeff,
       I usually tend to overdo things to be safe. If I were you I'd remove what you have now and use PL Premium glue ontop of each joist as you drop the plywood down. Personally 3/4" is fine but I prefere a dbl layer of 1/2"  using "screws" to fasten the plywood then I like using Wonderboard rather then any other CBU. Now ya have one solid floor. Course you could do a mud job over wire mesh if you want.
    Be a wall
            Don't get floored
                                 Namaste
                                             Andy
    You don’t complete your inner work before you do your outer work. Nor do you say, "Well, the hell with the inner work: I’ll go do the outer work because it’s so important and pressing." That’s not conscious either. The conscious thing is the simultaneous doing of both. "Ram Dass"
The Perfect Palette for Picking Paint Colors
For your next finishing project, look no further than the Colours of London, a curated collection of 120 colors from Mylands.
  • Podcast 460: PRO TALK With Builder Keith Bohling
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Tool Guide 2022
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
