Simplified explanation:
I have a raised slab enclosed porch. Found termite/water damage under several sliding doors.
The wood under the door sill was installed directly on top of the concrete but it was primed and painted
I removed the rotted wood from support posts and under door sill.
I now need to replace it and do not know what material to use.
I would like to paint whatever material I decide to use.
Any suggestions
Thanks in advance
Edited 5/5/2008 4:36 pm ET by Bocote
Edited 5/5/2008 8:14 pm ET by Bocote
Edited 5/5/2008 8:22 pm ET by Bocote
I'm not sure ofall you just explained, but any wood in constant contact with masonry should be PT to resist rot, Crete will wick water up.
