Anybody with experience using the Super Bee floor sanding machine?
No, but the Dodge Super Bee was a pretty hot number.
Plymouth Super Bee and the Dodge Daytona..
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming.... WOW!!! What a Ride!
I think you got it right!
up the ante... Can you say Hemi...
BTW... Put m app in for that job that I sent you the description on...
Just make sure they know that you have an assistant and you dont work without him(me)
can do... Don't know about the money but most of the bennies package is all you can eat...
Haven't you started your prison term yet?
I'm too rich. I'll find a way out of it.
yes, my company actually owns one. Great for small remodels, esp where thw client is still living in the house. Very little dust. use the least aggressive pad. takes a lot of time to get out the little half ciecles left from the vibration. Vaccum well between each sand to remove grit feom the floor. we also damp mop between coats to reise the grain to get the hook circles out.
not familiar w it, but that's type seen diy'ers get decent results with start w less aggressive paper to get feel of machine can always switch to heavier grit always keep machines moving try to operate straight line and in consistent manner and speed if ur careful it will work out if it takes standard center hole edger paper, try to get 3M Regalite sanding discs, better backing paper, run cooler and load up less
