Survey: Window Casing Installation
JourneymanCarpenterT | Posted in Tools for Home Building on May 14, 2008 08:59am
What are all of the hand tools that you use when you install window casing that you do not use to install door casing?<!—-><!—-> <!—->
If there are any tools that you use for window casing, but not for door casing, or vise versa, pleas explain why.
–T
  1. cliffy | May 14, 2008 09:09pm | #1
    I use the same tools for doors and window casing.  I usually mitre casings so obviously sharp blade is the primary tool.  The next tool is Jim Chestnuts Clamps.  Absolutely a fantastic investment.
    Have a good day
    Cliffy
  2. Chucky | May 14, 2008 10:30pm | #2
    all the same tools as for door casings but my windows frequently have a shelf and apron so i might use a 45 degree square to mark the returns on the shelf.  Depending on how i fasten it, i might use countersink and a screwdriver.
  3. maverick | May 14, 2008 10:36pm | #3
    a compass to scribe the ends of the stool to the wall.
    then a coping saw to cut it in
    might use a sanding block to round over the ends of the stool
  4. sledgehammer | May 15, 2008 01:02am | #4
    Once it is milled at the factory loaded on a truck sent to my lumberyard who then delivers it to the job.... It's then cut to exact sizes, trimmed here tweaked there some drywall bashed out...
    All the hand tools I need to install it is a hammer and a nailset, but I prefer a nail gun.
Fast, Accurate Wall Framing
