I have a chimney that is framed with 2×4’s with plywood sheathing and then was covered with synthetic stucco. The stucco has appeared to have cracked in some spots and shows signs of some effervescence around the cracked areas. I can see inside the chimney area from inside the attic and see no signs of water damage to the plywood sheathing. I am planning on replacing the stucco with the hardi-plank cement type boards. My question is do I need to remove all the stucco or just place the hardi-plank boards over the top of the stucco? I
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
Remove the stucco. You will find it comes off fairly easily. Don't know about the efflorescence, but do a google or hotbot search on 'EIF class action' is you want to know more about synthetic stucco than you wanted to know.
I have a chimney that is framed with 2x4's with plywood sheathing and then was covered with synthetic stucco. The stucco has appeared to have cracked in some spots and shows signs of some effervescence around the cracked areas. I can see inside the chimney area from inside the attic and see no signs of water damage to the plywood sheathing. I am planning on replacing the stucco with the hardi-plank cement type boards. My question is do I need to remove all the stucco or just place the hardi-plank boards over the top of the stucco? I
