ive got a bosch 4000…its about 2 years old …it gets used but not in production
i ran a 2x through her the other day worked fine than a ran a second board through it and the main breaker popped…which i have popped before with the vac running,,,
now the motor turns real slow and in reverse…should i just get a new motor or get an all new saw? or is there something else i could do to fix it
thanks
IIRC it has a 3 year warrenty...
WOW!!! What a Ride!
"now the motor turns real slow and in reverse.."
I have an old toaster that when you put in a slice of bread to toast, it comes out frozen when it's done. You think it's got the same problem
Aliens....?
Sorry, but I've never heard of your problem.
Rod Serling, where are you now?
Sounds like start circuit points.
Mine get dust in them and need a good shot of air now and then.
Infrequently they need a disassemble and a kiss with a point file.
Remodeling Contractor just on the other side of the Glass City
Shoulda bought a Harbor Freight.
They run backwards full speed?PAHS Designer/Builder- Bury it!
Yeah but they need chinese electricity.Spheramid Enterprises Architectural Woodworks
Caution.
Make sure you are using a proper receptacle for that Chinese electricity.
View Image'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
See? Y'all thought I was making that up.Spheramid Enterprises Architectural Woodworks
nah, not you, you would never do that !.
Steve,That's a good one!Chuck Slive, work, build, ...better with wood
;)Spheramid Enterprises Architectural Woodworks
That's just mean!Rebuilding my home in Cypress, CA
Also a CRX fanatic!
If your hair looks funny, it's because God likes to scratch his nuts. You nut, you.
Just flip the blade and feed from the other side. :-)
Edited 2/11/2008 7:52 am by dpsours
the start winding has lost its fluxy,
a bad start capacitor.... is this a one hump or two hump motor ?
or sawdust in the centrifugal switch
or the cent. switch is just bad or .......well that's about it
easiest thing to do is give it a shot of air..
just unplug the thing while you're working on it .don't need any loose fingertips laying around.
and DO NOT forget to discharge the capacitors before you even touch them
Edited 2/11/2008 9:16 am by maddog3
It aint got no lumps - it's a universal direct-drive motor.JT
then the problem must be in whatever fancy electronics Bosch uses .
shot of air ...check''calling bosch todayf,in p.o.sim pretty clueless when it comes to electric motors ...i meen i know why they work
and some of the parts but not any you guys are talking about
Good Luck, keep us informed eh?.
I'd turn it on, and jab the blade in the right direction with a little stick, see if it goes the right direction. Of course that won't fix it or prove much of anything. Unless you're lucky. You feeling lucky today?
