Existing: Frame construction, brick veneer over 1/2 gyp. Bd. sheathing. (1970’s const.)
Object: Install new door thru exist’g wall. Had removed the int. S/R from that wall and had started to remove existing framing as necessary.
Problem: Termites had eaten the paper off both sides of the sheathing up to about 4′ above the floor. At the first good lick with a hammer, all that is left is a pile of chalk on the floor. Not a big problem reframing/replacing the sheathing from the inside, but how do you handle the brick ties?
All brilliant ideas will be greatly appreciated.
Just throwing ideas out with no experience....
Drill holes through new sheathing and spot spray foam?
