Testing for Bad Drywall…
BilljustBill | Posted in Construction Techniques on June 11, 2009 05:45am
With the news and problems about drywall turning things black,  I’ve got about 30 sheets I’d like to test before I put them up.
Any suggestions as to what tests or procedure one could use to check and see if these sheets are good or bad?
Bill
  1. Danno | Jun 11, 2009 02:07pm | #1
    This will be mostly a "bump," but maybe the "sniff test"--see if it smells sufurous. Maybe take something like aluminum foil and put some sheets of it on the pile and then put plastic sheeting or a tarp over it to hold in the outgasses and see if the foil corrodes? Don't really know. I suppose you could send a sample to a test lab.
  2. Tim | Jun 11, 2009 03:31pm | #2
    Testing is very controversial. It makes bad teachers look bad and the unions don't like that. Those that don't test well could have their self esteem harmed for life.
    Edited 6/11/2009 8:32 am by Tim
      lindenboy | Jun 11, 2009 05:04pm | #5
      Let me get this right:  If the drywall tests bad, it surely is the testing agency, not the manufacturer?
      Do you see how $illy your logic is?
      Edit:  Can you believe that "$illy" is an unacceptable adjective here at BT?
      "It depends on the situation..."
      Edited 6/11/2009 10:05 am ET by lindenboy
      1. Righty_Tighty | Jun 11, 2009 05:31pm | #6
        I think $illy was his intention.  My wife's a teacher, so it made absolutely no sense to me ... which is perfectly consistent with our public education system here!
        Now that we can dismiss this $illyness, lets get back to taste testing drywall ... fwiw, I just saw a video tip on the FH homepage that might help with repairing all the bite marks after install.
      2. Tim | Jun 11, 2009 07:31pm | #7
        No logic was used in my post whatsoever. I know nothing about testing the dryness of a wall. Silly, isn't it.
  3. marv | Jun 11, 2009 03:54pm | #3
    Is the drywall marked by the manufacturer?
    You get out of life what you put into it......minus taxes.
    Marv
    1. BilljustBill | Jun 11, 2009 07:48pm | #8
      I'll go check who is the maker...but from another posting, here at Breaktime, I watched a news video that now shows American manufactures may be adding the scrubber stuff from coal fired generation plants into their/our drywall...
      Come to think about it, I did have an urge for Kung-Pow chicken and to fire up my old coal stove with my antique coal shovel...after just counting all those sheets of drywall....
      Bill
    PaulBinCT | Jun 11, 2009 04:31pm | #4
    Could try eating a piece... if you're hungry again an hour later...
    PaulB
    http://www.makeabettertomorrow.com
    http://www.finecontracting.com
Fast, Accurate Wall Framing
