T&G V-joint wainscot question
rshelton | Posted in General Discussion on March 23, 2006 04:03am
I’m finishing out a basement for a customer. They want one room to have V-joint wainscot installed at a 4′ height. Since there is no sheetrock yet, I’m considering installing 1/2″ CDX (instead of sheetrock) along the bottom half of the walls to use as a nailer for the T&G. Does anyone see a downside?
  1. FastEddie | Mar 23, 2006 05:05pm | #1
    Interior or exterior wall?
    JDRHI | Mar 23, 2006 07:58pm | #2
    I do it all the time.
    J. D. Reynolds
    Home Improvements
  3. mojo | Mar 23, 2006 08:36pm | #3
    We've done something similar but used 1x3 spruce for the nailers.  Should save you a few dollars over the cost of plywood.
  4. chascomp | Mar 24, 2006 12:04am | #4
    I'd use no ply or drywall. I've usually put insulation between studs, inlaid 1X furring strip horizontally at the top, center and bottom of the area to be covered (4 foot high may take two strips in the center) Then with my nail gun I can toenail thru the tongue and be done faster than I can tape the drywall. I am assuming you are using 3/4" T&G material not the 3/8". If I'm wrong then plywood is a must. Then you can glue and nail pretty quickly.
    The older you get the more the journey matters.
    1. rshelton | Mar 24, 2006 03:09am | #5
      Thanks, guys.I'll be using the 3/4" T&G, 6" v-joint. I WAS worried about matching thicknesses with the 1/2" sheetrock, but I don't reckon it matters since the trim at the top will cover any variences. Also, The furring strips will save ~$50 in material.
  5. notascrename | Mar 24, 2006 03:23am | #6
    I'v had problems when the wood was not acclimated to the room for long enough. darn stuff tried to explode off the wall. Jim Devier
  6. hvtrimguy | Mar 24, 2006 05:09am | #7
    I've done wainscotting all different ways. Plywood makes for a flatter surface and can be floted over studs with construction adhesive. Then the t and g will lay flat. I've also installed t and g ove inset 2x blocking and unless this is done meticulously, the results are a wavy wall. The things to keep in mind is the top trim detail (chair rail), the base trim at the bottom and how it will wit door legs and finally if any windows fall part in the wainscotting and part in the rock.
    I've even considered furiing out both the rock and the wains so that the faces all line up. Then all you need is deeper extension jambs and trim as usual.
    Hope my ramblings help. Later
    Jason
      JDRHI | Mar 24, 2006 04:27pm | #8
      I've done that in the past.....I actually prefer the look of the wainscotting sitting proud of the drywall/plaster wall surface. A good deal of extra work, but wholly worth it IMO.
      J. D. Reynolds
      Home Improvements
