The main purpose of hot dip galvanizing
Hot dip galvanizing:Is an effective way of metal corrosion.Mainly used for various industries of metal structure on facilities. Is will rust removal steel parts into 500 ℃ or so melting zinc liquid, make steel component surface adhesion zinc layer, thus plays the purpose of corrosion.Hot dip galvanizing process:acid washing – water washing -plus help solution – drying – hanging plating – cooling – medicine change – cleaning – grinding – finish.All the ground screw of Leah ground screw the galvanized thickness can reach 85 um-150um. www.ground-screw.com [email protected]
Thank you!
This is the best example of an attempt at spamming a board that I have come across.
Nah, it hardly makes the top ten.
Top this........
" Hot dip galvanizing:Is an effective way of metal corrosion"
(And that is some of the worst (best?) Chinlish we've seen here in a while.)
