I went and visited a house the other day and it had a balcony the was about 8′ wide and 20′ long. The balcony had a tile floor.
I know that the framers used PT joist with a 3/4″ Osb sub-floor.
I don’t know what happened after that.
How do yoiu suppose that they finished this?
berrrry, berrrry, carefuwlwy.
I've installed copper flat seam roofs under similar details. One that I did had a built in gutter with drains running thru the supporting columns. I've also flashed with copper so a pourable membrane could be installed under the tile. I did the flashing first and then the membrane was poured. I only saw before and after and did not witness the membrane being installed. Maybe Boris Yeltsin will spot this thread and enlighten us.
