Tile on a laminate countertop
leftisright | Posted in General Discussion on March 11, 2008 03:37am
If you were to want a countertop that is only going to last at most five yearsd, hopefully much less……..is it possible to tile over a laminate countertop?
Wife saw this on the diy network, yah just scuff up the countertop with a grinder, cut off the backsplash with the sawzall and slap on the thin set and set dem tiles. I’m thinking might make it through one dinner party but will fall off after that.
I was thinking…..cut off the backsplash, then screw on some hardibacker tape on the deck and the front lip , tape the joints and then tile away.  Only problem is bump on the front that keeps the water from running on the floor.
By the way this started as a replacement for a garbage disposer, that led to a new kitchen sink and then the sink led to a new faucet….well you see where this is going. Probably going to gut the kitchen in 3 to 5 years so don’t need a permanent solution.
SWMBO has stated no more laminate countertops……
  1. FastEddie | Mar 11, 2008 04:53am | #1
    As long as the laminate is well adhered, there's nothing wrong with tiling right over it.  But I would add a layer of 1/4" hardie.  Easy and cheap to do, screwed and thinsetted it solves the potential laminate problem, and you can solve the problem with the bump in the front.
    1. leftisright | Mar 11, 2008 05:03am | #2
      So you would thinset underneath the hardie and screw it?  I was getting the impression that the thinset would not adher very well to the laminate if it wasn't scuffed up, but heck it aint going nowhere with a lot of screws right?
      1. FastEddie | Mar 11, 2008 05:13am | #3
        Use a random orbit sander with 60-80 grit paper to take all the shine off.  My Porter cable has a dust hook up, so it works well inside ... if I remember to turn on the vacuum ... and then if i remember to change or clean the filter.
        Anyway, then a thinned layer of thinset, then the hardie, then screws countersunk into the hardie.  You don't need to wait for the thinset to set before laying tile."Put your creed in your deed."   Emerson
  2. seajai | Mar 11, 2008 06:11am | #4
    Construction adhesive sticks to everything. I wouldn't recommend it as a way of setting the tile permanently, but if your looking for a short term solution, I think it would hold up until you made it to the grand remodeling.
  3. cliffy | Mar 11, 2008 06:16am | #5
    There was an article in the magazine a few years ago with this very method.
    If I recall it worked great.
    Have a good day
    CLiffy
    1. leftisright | Mar 11, 2008 06:46am | #6
      Yeah but you gotta pay to use the magazine archives and the advice of you guys is free!!!!!
      1. cliffy | Mar 11, 2008 06:07pm | #7
        I would have to over to my drafting table and look through a hundred and some magazines of FHB to find it.  What I do remember though is he used cement board in a thin set to the old laminate counter, then also a vertical edge at the front same way. Then he tiled over the whole works.
        Have a good day
        CLiffy
Flashing a Window Using ZIP Tape
Travis and Joe walk through the step-by-step process of prepping, caulking, and flashing a window using stretch tape and flashing tape from ZIP System.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
